My 94 Classic cranks but i am getting no spark.
The car ran fine - needed a tune so i replaced plugs, Plug leads, ignition amplifier on the side of the distributor, coil, rotor arm and now she will not start.
I traced the fault to no spark at the end of the leads. I took the coil HT lead and checked for a spark against the body - no spark. The small wires at the two connections on the coil both have voltage when the ignition is turned on. The fuses in the main fuse box were checked - the one for the ECU (the red fuse) had blown. I changed it - still no spark. There are no fault codes on the display.
I am baffled.
I am baffled.
