I am in the process of an engine swap. Upon the first attempt at starting the new engine, I discovered no fuel.
I went to the back to diagnosis, I removed the fuel relay, and there was no signal to the relay to turn on the fuel pump.
Where should I look next to figure out the issue?
According to the electric schematics, I should check, Relay-Engine control module ECM R116, any idea where that is.?
Start by checking the fuse in the glove box. It should have a card stating which fuse to look at.
I believe there is also one below the relay in the rear.
Both fuses are good.
When key is on, the front fuse has voltage with voltmeter.
I did relay testing.
The power for the pump has voltage, and the pump wiring is correct. If I supply voltage, the pump turns on.
On the relay solenoid/coil part, when key is on, it has a ground, and supply does not have voltage. (and it should.)
Referenced to : Page 90
http://www.super7thheaven.co.uk/wp-...-circuit-diagrams-range-rover-new-uk-2001.pdf
Based on the diagram and my testing. the issue is between the front box fuse and the relay.
Thoughts?
Looks like you are doing everything correct. Did you try swapping relays or running a jumper?
See this video: https://www.youtube.com/watch?v=c2p42q-cfYw
Otherwise you will have to fault trace the wiring, which can be found in RAVE (see sticky section if you don't have it and download). In RAVE look at the Range Rover Electrical Circuit Diagrams - then under Fuel Pump - on the PDF that comes up it is page 83/190.
Range Rover MkIII / L322
Does the engine crank when you attempt to start it? The problem may be with the Engine Control Relay as you mentioned in your first post. It is the blue relay in the E-Box. C1895
Technology Action figure Fictional character Games
