Hi all and thank you in anticipation
i own a 08 tdv8 which up until now barring the stereo making its own mind up wether to give me sound or not has been reliable,but yesterday I started having numerous faults coming up on the message centre ,followed by airbag light,auto lights light and every fault that’s probably on the ecu all eventually won’t off when I took my lad to football.when we got back to the RR about an hour later I turned the key and nothing barring a flashing red park brake light ,call Mr RAC man checked the battery and said i5 was showing 12.4 volts so he attached the jump leads and left it running for a while .After about 20 mins nothing and after a bit or wire waggling all the ignition lights came back on so I quickly started her up and limped back home. When to it this morning turned the key and nothing (as a dodo) and left it all day , gone back tonight to try again and presto started ,turned it off straight away and tried to restart ,nothing again
any ideas please or is it just a case of a dodgy battery as first thought
btw love this forum
check the battery terminal connections clean them then refit the terminals check the grounds as well
Battery and terminals fine ,looks like a ignition barrel problem ,is there anyway of testing the barrel without stripping the dash please
Check your brake light switch you need a brake signal in order to turn the key.
