my range rover has stopped ,i was drivin when i heard a noise sounded like i had run over a plastic bin, then has if someone was pullin me back, it lost power then transmision fault come on. i stop , i tryed to pull off again and it was makin a load noise from back rear pas side , then it would not drive, turned key of, tryed again drove 100ydrs sounds and felt has if hand brake was on. then would not drive has if the diff was locked!! the recovery truck come and it drove on ok weid any advice please help
You have a 2003 model I think? It definitely had the front diff./front propshaft recall work carried out?
Phil
Phil
yes 2003 30 td6 i was told when i bought it it had had a new gearbox at about 60k its done 94k now!and when i moted it last mounth the guy in garage said looks like its had the recall on front diff
