Hello,
Picked up 05 RR Westminster on Friday, has 152k, very nice truck.
Have inactive suspension display on dash, no lights on the height control knob, fronts are lower than normal height and rears are way up above normal height. It seems stuck in this position. I was thinking maybe height sensors? Any one in Atlanta GA area with EAS tool and wouldn't mind resetting/reading code?
Have service appointment at dealer for oil and filter change, they said they will do multi-point inspection but diagnostic charge for any item is $180.
How is the RSW All Comms tool versus other tools? It seems RSW All Comms tool can be used to calibrate all corners?
I had to replace the battery and didn't know about doing something with the steering right afterwards as stated in repair manual, could this have caused a fault?
Also Navigation screen is frozen on Land Rover startup display, any idea on what this could be?
Thanks for your reply.
I look forward to enjoying the ride.
Thanks,
Ada
Thanks,
Ada
