Hello,
I am new here (please bare with me). I have a 2005 Range Rover HSE.
I am in need of finding a cost efficient way to replace a headlamp that went out.
I also need to find a way to reboot, or repair a navigation system that went out. Screen is completely blank.
Can anyone make any suggestions?
Thanks so much!
Re: NEWBIE needs help with 2005 Headlamp, and Navigation system
try craigslist, kijiji.ca and ebay.
also check your local junkyards.
google.com
G
Guest
What do you mean "went out"? Did it pop down the shops or go to the disco?
It may be your bulb, it may be your igniter, it may be wiring, it may be your switch, it may be....
We need more information on the failure and what lead up to it.
If you know someone with the same car as yours, you best choice would be to swop parts to identify what might fix the issue. Same goes with the navigation issue.
Someone on here just had a similar problem to yours, check this thread out.
viewtopic.php?f=2&t=38993
But again, we need more info. Did your screen start to fuzz, have lines crackle, or just go black? Do you still have the radio or other on board meassages? Can you see those messages on the instrument panel? Does the little red light on your GPS unit [In the back end of the car} light up when you have the ignition on?
Lots of questions.
Oh, and put your location in you name box, helps us to help you.
