Interesting new bulletin on TPMS valve sensors. Apparently, they can break and leak air when removing dust caps or checking tire pressure? What is interesting is that Land Rover is instructing its dealers to replace all 4 or 5 sensors, not just the broken one(s)... :think: There must be an issue with the sensors installed on current cars (06 through 09, see VIN range in the bulletin), otherwise I don't see why Land Rover would go through the trouble of replacing all of them, considering their cost and the labor involved.
Note (this was issued earlier as a Special Service Message), no metal caps on TPMS sensors! If you remove the plastic dust cap and put a metal one on, your warranty on the sensors is instantly void.
