I bought a 1997 P38 4.6 HSE in January and in the recent rains we've had in the UK the driver's side headlining, in between the windscreen and sun visor, has become noticeably soggy and now after heavy rain you can see water marks running down the outside of the driver's side pillar towards the air vent. I initially checked the sunroof drains to see if it was blocked but water was running down the drain just fine when tested.
My question is do I need to take out the headlining to find out where the water is coming from (which I can not keen on doing unless I have to) or is there a simpler solution to this?
Also is it easy to replace the drain tube which I suspect has split or will I need to dismantle most of the interior to get to all the clips and fixing between the roof and the wheel arch?
I do have a copy of the RAVE but cannot see in there a procedure for fixing this.
In addition I would like to know if the air suspension is slow to fill after being left in access mode (5-10 minutes to return to standard) if I need to investigate the system for leaks or the air compressor is on it's way out.
Any help would be greatly appreciated.
