I heard today that the new Range Rover Supercharged is fitted with BEMBRO drilled and slotted rotors.
Does anyone konow if this is indeed true? If so, can these rotors be used on a 2007 RR SC?
Re: New RR SC fitted with drilled & slotted brake rotors?
olbear,
They are not Brembo's. Also they are larger diameter, 380mm (15in.) compared to 360mm (14.1in.) so they will not simply bolt on. The calipers are also 6 piston compared to 4 piston. ibis1 ;)
Hmmm, I smell a project coming on :)
ibis1, thanks for the info, am getting ready to jump and buy new rotors & pads. Want to give drilled and slotted rotors a try.
Where are you planning to get your D+S rotors from? Also, are you going to run ceramic pads up front? I have an 06 SC that is also getting to need a brake job, and I have heard that the right ceramic pads will cut down on the brake dust.
thanks
thanks
This is what I am searching for now. My company relocated me in Jan '10 and live in Edmonton currently. Looking in Canada to find a good supplier for D&S rotors. I haven't made contact with any manufacturers as yet. Disc Italia, EBC, Baer, StopTech all come up in searches and seem to be good products?
Not sure about ceramic pads, some folks have commented that the stopping power is slightly diminished during everyday driving. I can put up with the dust, I don't want diminished performance.
Have been some good write-ups on our forum of brake replacements which have been very helpful, If I was back in USA it would be a tad easier to order items. I don't want to bring items up over the border and get "hit" with huge duties or taxes, not to mention the high shipping rates.......
