Hello all,
I am the proud owner of a 03 RR vogue (UK based). It is the 4.4 petrol and I love it.
I really did not want my first post to be a load of questions but....unfortunatly it is.
We were at the beach last week end. On the drive home the warning light came on (exclamation mark in a circle). The display reads 'check brake pads'.
I have done some reseach and I am going to have a go myself!!!!
I have found the video walkthrough etc, however I have some more questions.
I assume it is the front pads but is there any guarentee? Should I replace all the pads?
There has got to be a wear sensor of some sort - do these commonly fail or need replacement? Also will the indicator and error message clear itself when new pads are fitted?
Do I need or should I bleed the brakes at the same time (pedal feels a little soft but but that might be due to thin pads?)
I like the idea of the EBC greenstuff pads (fronts about £75 rears about £58). Opinions please!!!
Finally any hints or tips to make this go smoothly!!
Thanks in advance
Dan
Thanks in advance
Dan
