Hey guys, I've been a LWB owner for about 9 years now but after someone rear ended me (not catastrophic) and two weeks later the oil pump went out I decided to put the LWB away for a little while and add a second Rover to the fleet. I came across a 2000 HSE that is in very good shape other than the engine. The shaft on the water pump had come loose leaving the pulley dangling off the end of the pump. The previous owner had his friend work on the truck, and it appeared he was intending to do the head gaskets and gave up hence the reason for selling the truck. The AIS pump had been removed, the upper intake was partially removed, as well as the maf and all related plumbing. Nothing was missing, the EAS pump was recently replaced, the engine would turn with a wrench with the plugs removed, and everything else seems to be in good order. I picked up the truck for $2500 and towed it home.
I decided to go ahead and do the head gaskets, as the work had already been partially done. I disassembled the rest of the way and everything went smooth except the rear 3 or 4 bolts on each head came out very easily. I took the heads to the local machine shop and they cleaned and pressure tested them, ground the valves and the seats, put in new seals and surfaced the heads. I do not know how much he surfaced them.
Everything was going well until last night I went to put the lower intake back on and it does not seem to line up. I put the new gasket seals in place, positioned the clamps, and bolted but not snugged them in. I put the valley gasket in and it would not line up correctly. It seems like if I line one side up, that it is too wide and over shoots the bolt holes on the other head. I figured maybe it kind of pressed into place once the lower intake is pressing on it so I go and put the intake on and I seem to be finding the same issue. And it's driving me nuts.
The heads can't be in the wrong place as the are located by studs in the block. When I bolt one side, the opposite side does not line up, I can see maybe 3/4 of the hole the bolt should go in, maybe more. I can force the bolt in without cross threading things, but not all the way, and upon removal, the bolts threads were starting to cut into lower intake. Is it possible that the shop ground the heads down so much that the intake no longer fits?
If so, and I'll be calling them on Monday, what am I looking at? I could conceivably machine the lower intake a bit and it would fit, the valley gasket might be a challenge. New heads? Taller gaskets? I'm going to go look at it with fresh eyes here in a bit, I was about 6 hours into it late last night. Thanks for reading my long winded post, and I have pics of the whole process if anyone is interested.
