Well i had a bad oil leak from my oil pressure switch, replaced it and that leak stopped. Now im noticing there is a small leak coming from the bottom left of the radiator. I assume its from the oil cooler or one of the hoses leading to to. Anyone have experiecne with a leak there and some insight on what it could be?
Thanks.
Oil coller or tranny cooler. If you pull your fan shroud and slam panel you can lift and lean your radiator towards the engie and inspect them. An old piece of cardboard will protect your radiator from the fan blades.
