1 - 1 of 1 Posts
I found this forum a while back while I was researching Range Rovers. I just bit the bullet on a used 2006 Range Rover HSE, and I love it. Although I learned that it's pretty easy to lock the key (I only have one) in the rear trunk. It turns out that if you use the rear trunk button to unlock the rear and then close it, it locks. If you've left your key inside, you're locked out. If you're locked out, the only way to unlock it is to tow it to a dealer. Who will charge an hour of labor to unlock. At least I had AAA, so the tow was covered. Lesson learned. I really love the truck, though. And I've ordered a second key.
Jon
1 - 1 of 1 Posts
