New Halos Awesome, Now Adaptive Headlight Warning! Help!
6882 Views 11 Replies 5 Participants Last post by  32N110W
Hello All,
I have been lurking awhile and have gotten a lot of cool ideas from you all. Thank you. One of those ideas was some of the very sharp angle eyes that jbrac25 does. After getting a DIY kit from him and installing this weekend, we have a very cool and unique look on my wife's RRS. I must thank him for all of his tech support. I am sure I would have been shopping for some new headlights without his advise!
During the install I plugged the first headlight in after wiring it to check function before doing the other one. I noticed the adaptive headlight warning flashing on the dash when I did this but just assumed it was noticing the other light missing and would go away when both were hooked up. Well, I was wrong! After a flawless install and great looking halos, I still have that warning light flashing and the adaptive lights are not functioning. I did unhook the battery and let it set for at least 30 min. with no luck.
Anyone have any ideas or know how to reset the adaptive headlights? I checked all three fuses that seem to be linked to the system too. Thanks in advance for the help!
1 - 12 of 12 Posts
Re: New Halos Awesome, Now Adaptive Headlight Warning! Help!
eyeguy said:
Hello All,
The warnings take a few days to reset. Give it a few days, if it doesn't go away, then light the interior on fire and douse with butterbeer.
Thanks. I'll have to remember that back-up plan! I will give it awhile to reset then. Anyone else have this happen before? Did your warning indicator eventually reset?
So did you warning light reset?
Not yet! Starting to worry I messed something up. I don't know, I guess a trip to the dealer is next to see if they can reset it?
Couple of days? Take the halos out when you hit the dealer!
Couple of days? Take the halos out when you hit the dealer![/quote]
Monday thru Thusday with me not messing with it. Truck driven and started multiple times everyday. Truck is out of warranty so at least I don't have to remove all of that work to see the dealer! Any other ideas out there?
Black electrical tape over the warning light.
WINNAR
Ha! My wife beat you to that suggestion! It is her truck so I might just do that. Save some money that way.
have you tried disconnecting the halos to see if the warning light goes away?
The halo inverters trigger the errant alerts. There Is no way around it, unless you take them out.
1 - 12 of 12 Posts
