99 Rover
Recently replaced air bags and re-placed all O-rings in valve block manifold.
Had to buy "Buddy Box" to re-set computer. Everything worked perfectly
Friday and Saturday, over about 35-40 miles. No air leaks.
Today my wife goes out to start the truck, air-suspension is lock in highest
setting (4x4), 35 mph message up, christmas tree completly locked on,
"Truck" idiot light is on in dash, , I tried to force error by deflating system,
and driving on bump stops, Buddy Box could not find error or reset.
What da ya think?
Mark
I think you have a Drive box error :(
Seems like too much of a coincidence that you would have an unrelated problem so soon after working on it. I would verify the valve block is as it should be per Rover Rennovations instructions. Then use jumper wires to verify individual spring inflation/deflation functions.
Pull it apart and re clean it before spending money. I get this some times, can even happen when driving. Cleaning the valve block fixes it.I put a new line to the tank and must have go some dirt in it that comes back the line randomly. I will have to remove all lines, blow them with air and re clean the valve block I think to keep it from coming back.
