So apparently every time I try to move my seat (drivers) backwords it blows this fuse, any enlightenment????
SUPER MODERATOR
pinched wire? short in the switch? Swap the switches from the passenger side and see if it does the same. If it does the same I would guess jambed motor or transmission. If it doesn't then make the passenger suffer until you get new switches.
SUPER MODERATOR
The motors turns a gears and screw drives etc. A froze up gear section (transmission) will peeve the motor off adn it'll blow the fuse.
