have a lynx diagnostic kit for range rover and plugged in as the air susp is in active, changed the air suspension bag and now tried resetting found the following fault codes..
122 RESEVOIR PRESSURE RISES WHEN LIFTING.CURRENTLY PRESENT
103 TOO MUCH ENERGY FOR REGULATION NEEDED. FRONT AXLE. CURRENTLY PRESENT
127 FRONT LEFT HEIGHT SENSOR ACTIVITY INVALID. CURRENTLY PRESENT
31 FRONT RIGHT HEIGHT SENSOR. CURRENTLY PRESENT
50 CAN bUS FAILURE. CURRENTLY NOT PRESENT
Can anyone help me to understand what i will need to know to sort the issues. tried google.. no use, thought you guys may be able to help..
THANKS
