Sorry to be a bother, but my copy will not run on mac, nor on my old HP PC... Think it's the disk because other disks run fine.
Anyway I need some one to copy and send me the pages that have to do with the removal, and install of the water pump on the BMW motor.
I already have the pump removed (sort of) but there is a pipe that runs across the front of the motor, and I'm not sure what it is or how to remove it.
Mark.
Hi Mark, the pipe you are referring to is held in place with a M6 bolt (10mm socket) at each end. Remove the bolts and ease the pipe towards the front of the car. There is an "O" ring at each end of the pipe be careful not to loose them. The pipe does not contain any fluids.
Stewart.
Thanks Guys for the info.
The water pump replacement went well (so far), the cross pipe I was worried about was the Aux air injector system, and on my model I have found out that it's been disabled by the Factory (thru Tec 2) TB.
Mark.
