EAS block.JPG Do I need both of these kits to rebuild my EAS block in 2000 P38? Or does the X8R kit contain the everything but the bolts? There is some language in the sticky notes about need Atlantic British's kit STC 1803 but not sure if those same orings are already included in the full X8R kit. hard to tell for sure looking at the pictures. For example I see large black diaphragm in the AB kit that I don't see in the X8R kit....
Looks to me like the X8R kit is complete. The diaphram is shown as a metal/rubber ring on the 2nd column from the right, positioned inside a thin, large diameter oring. You recycle the existing disk of the diaphram, and replace just the metal/rubber external seals only.
buy the X8R kit. It contains everything for the valve block and the pump. You don't need the bolts unless yours are stripped due to a previous bodger.
