Good morning
I have a RRS 2011 that did not come with AFS
Looking at my IID tool I can see that AFS is marked as not installed.
Can anyone tell me if its just the headlights themselves that are AFS or if there are more components?
I ask as I am thinking about swapping the headlights for AFS units and then reprogramming the ecu to enable them
Has anyone tried or can see a reason this won't work! (For example is the wiring loom the same or are there extra components)
Dan
There is also a module, fuses that will need to be installed, and you may or may not be prewired for it. I'll see if I can figure out a way to check if the wiring is there when I'm at the shop.
That said, even though it is a good system, and does work well, I'm not sure it will really be a change worth the effort, I notice them more in parking garages than while driving.
Thanks RoverGuy,
If you could find out if the non AFS option still had the wiring in place that would be the clincher for me. no issues adding a module, fuses and lenses but wiring looms is a different ball game altogether!
thanks again,
Dan
