At that price, you probably have been sent an Armstrong OE spec steering damper and, most likely, a Lemforder OEM link. I've seen the prices offered for the OEM drag links and they are actually very very cheap. In fact I think this is one product where a distributor can make some good money.
If you have had a lesser quality unit sent, then it would have shown signs of wear by now. The OEM type ball joints have a rubber seat inside to reduce vibration. That's nice 'till water and dirt gets in there.
I've had the Bilstein damper on for a while and I'm still not 100% sure about the fit of it. When you put one on, it's not quite a perfect fit. I remember Dan_UK_1984 saying that Rimmer Bros (or one of the big distributors) removing it from stock as it didn't fit properly. Although I've had the Bilstein on for a while, I've wanted to put the Armstrong unit on I've had waiting to try. With the Bilstein, it is always trying to extend itself outwards, whereas the Armstrong is oil filled and is static.
Remember you can get 2 or 3 Armstrong units for the price of a single Bilstein, so the spare(s) can sit in the boot when on safari...
