1 - 10 of 10 Posts
i just got a 2003 hse silver, and i am looking to get 22's for it, any advice? i was looking to get the stormet wheels, does anyone have any pictures of their rr with 22 inch rims? or 24 inch rims, thanks. help will be greatly appreciated.
You should check the post below, I think this pretty much answers your question :)
viewtopic.php?f=2&t=37946
I live in Estonia and the roads are crap here. This means that I should not go larger than 19" in order to keep a minimum of ride comfort. Does anybody have pictures of 19" stormer wheels? What about replica's (do or don't)? I found some replica's that are cheap, but the offset is 50 instead of the standard 57. Currently I have some Mak Canyon 19" rims with offset 35 mm (just bought the 2005 RR last week) but the tires rub and get cut. Does 50 mm offset work?
just a bog standard Stornoway Vogue with style 8 wheels on - I like to travel incognito - well apart from the plates 8-|=
I have 22's on my 2003 range rover. the tire size is 285/35 r22 106v yokahama parada tires. and the clearance is fine even when i lower it and turn corners. any thicker rubbers on it and the tires will get eaten by the wheel wells. so these are the size of tires that i found that fit perfect.
Akon.
Check out aftermarket offerings from Overfinch for your model L322 or possibly www.speedywheels.com.au from down-under ?
I prefer forged wheels to reduce or maintain unsprung weight on each corner of the truck with appropriate tyres to match dude !
I'm back from the Solomon Islands boys.
Cheerio,
Vinniman.
'88 Highline
Perth, W.A.
1 - 10 of 10 Posts
