One of my OEM ballasts is shot, thus the light only works about 30% of the time. Any ideas as to what I can do here? do I get another ballast through the dealer? I'd rather not because they are going to charge an arm and a leg. Is there anyway to get the ballast elsewhere so that I can install it on my own?
Hey have you swapped the bulb over to the other side or examined the connections? I had a bulb flicker for a few weeks, then it just died... Swapped in new bulbs and everything fired up fine.
I know if you search the forum there are some part numbers for the ballast itself if that is in fact the problem. Maybe if you switch the working bulb over to the troubled side it'll work, that being the case buy the bulbs online as the dealer gets 300 per bulb.
