Re: need instructions for removal of panel to access subwoofer
okay, im still a bit lost and unfortunatley cant read a diagram to save my life
anyway, lets see if i can describe what i did and where i got stuck
here's what i removed
the first panel which hides the nav (no brainer)
lift the spare wheel compartment up
remove little black plastic gromet from floor of second panel (the subject panel)
remove two little grey plastic clips (they look like they hold a cargo net in place)
remove the metal bracket thing from the floor which holds the panel down
remove a piece of plastic from top of trim near the window - which exposes 2 torx screws
remove those 2 torx screws and removed the metal clip that they held in place (the clip keeps the cargo cover thing in place)
basically at this point, the subject panel is free from the bottom -- but is stuck in place up top near the window -- i think i need to remove the leather panel that is next to the rear seats (i.e, the leather panel if you open your rear door and look to the left - holds the seat belt in place) -- but not sure how to do that
either that, or i need to completely remove the plastic trim pieces from the upper edge of the rear compartment
am i making any sense or do i need to take photos ?
i have a feeling i have 75% of it removed - but am missing some steps
