This is the second time happened, when I backing up my RRS, I put in reverse gear, release the E-brake along with brake. The car wasn't moving at all. Feels like something stucked. I have to give a little bit gas to let it go. Then I heard a noise feels like I run over something. I can't find anything below the car. Do you guys ever experience this situation? I have a 2011 RRS gt edition with 44k miles. Thanks for all the inputs and help
Sounds like your Electronic Parking Brake was stuck...cycle it a few times...you should be ok. You should hear the motor engaging and disengaging when you cycle it.
ok will do thanks,I thought there probably have issue with my tranny or axles
Sounds like you're still in factory warranty. I would take it in, and have them check out the parking brake shoes, these fail pretty quickly if stuck engaged and driven. It can turn into a costly repair that would be on your dime if it fails once you pass 50k miles.
There is also a chance that you just didn't hit the P/B switch enough, and it was still fully engaged(hadn't tried to disengage) As soon as the throttle registers a 3% input, and the transmission is in gear, it will automatically disengage the P/B. But still, with your time/mileage situation, I would plan a trip to the dealership anyway.
