loose connection somewhere.
Check all connections especially battery, becm, alternator including ground connections
I dont think it would be Alt' related as the power would still come from the battery etc (although it is still worth checking that the output is around 14.5V). However I would seccond the suggestion of double checking the connections to the battery first.ygzzbn said:I am just guessing that it's an alternator problem. Any suggestions will be appreciated...
Yep, exactly the same thing. I checked already all of the connections (especially grounds). They're all Ok I guess... Probably I'll change the alternator.Jos Geuze said:Hi
If you mean by blinking that the intensity of the light is changing then yes it can be an alternator problem.
I have had the automatic voltage regulator failing on my alternator causing a flickering especially visible at night in the ac display whith the frequency depending on the revs of the engine (press the accelarator and the light flickers faster). The voltage regulator is an integral part of the alternator and could not be changed seperately (i was told, i didn´t take apart the old unit to check) which resulted in having to buy a complete new alternator which solved all the problems.
Regards
Jos
This weekend a friend of mine will have a look on alternator, brushes and everything. It will be like an electrical surgery. Because lately I am having some troubles again. When I flash the headlight, my radio is going off for a second. The battery is not that old (only 1/2 years) but maybe I have a bad alternator. We'll see... Thanks for your reply.viperover said:Batteries are important on the Rangies, a duff one will send all sorts of problems like gearbox fault etc and problems like you had, my guess is new battery soon and make sure its a nice hefty 100amp (800CCA) sealed type
