I have an 06 hse with rear entertainment system.
Recently my DVD player will only play elmo DVDs. It had Disney movies in it before that use to play ie wall-e bolt etc. The DVD player will not recognize any disc other than the Elmo one. I've moved all the discs around and it will only recognize elmos DVDs. The front menu will show there are DVDs in th changer but if I select another disc it will cycle around til it gets back to elmo. I've rearranged all of them so that emlo is in each of the six slots at different tomes and continues to only recognize Elmo. If I take Elmo out and replace with other DVDs the menu will black out to show a change but then will say that there are no discs in the changer. The player is set NTSC format which is what all my discs are. None of them are burned discs and are all originals. What's worng with my DVD player?
