Driving from Austin to Houston this morning and the front window no longer goes up. I can hear the motor run, when I look into the slot that the window should be located I can see the regulator going up and down.
I took off the door panel, removed the speaker and was able to get the window to a closed position, but it appears that the clips that hold the window onto the regulator have broken.
1) Does the entire regulator need to be replaced? Or is there a way to just replace the plastic clips that hold the window to the regulator?
2) Does anyone know of a video to watch to remove the current regulator? I have seen alot for discos and others, but not the L320/
Thanks in advance.
