1 - 14 of 14 Posts
Hello all, I am looking to have 50 mm air spring spacers fabricated for my p38. I need to know what the measurement on size and exact shape is for the d shaped hole that they will need to have in them. i have been reading on paulp38 lift guide and that is the only dimension i really need. i can get them fabricated in town after that. or if someone would like to be paid for it or has some lying around i will buy them from you.
Thanks,
Turner
JACK'S GRANDAD
So you just need the dimensions for the D hole?
Hi mate. If you look up Paul p38 on Google he has a lot of info on them. I'm thinking of doing the same thing.
Sent from my SM-G900F using Tapatalk
leftlanetruckin correct, I just need the d-hole dimensions so i don't have to take one out to find out, and rbanks182 yes that is where i got the idea from if you read above.
Thanks,
Turner
JACK'S GRANDAD
This?
If so, I can mic it out and send you dimensions
Luckily, I'm in the shop and at home, and have a spare set of airbags laying around......
Martin
yes please, that is exactly what i need! thank you very much, this forum is amazing for p38's and this is somewhere around my 10th post.
Turner
JACK'S GRANDAD
Rear, in mm.
JACK'S GRANDAD
Fronts.,
These are Arnott GenII bags, but the mounts will be the same as OEM.
Diameter of the base is 125mm on both front and rear .
Martin
Discussion Starter #10
rbanks, yea i was sure you had just looked it over, and leftlanetruckin, big help brother. I am taking some drawings to to get fabbed tomorrow. rbanks, if you continue with the idea let me know how it goes. as mine sits on stock height, i am running 265/75/16 on 4 inch backspaced wheels with a good bit of fender trim and i did bumper trimming to improve approach and departure angles. the pictures are at off road setting, so with the 2 inch spacer lift, as paulp38a has it, i should look like this at normal height when done. can't wait.
Thanks,
Turner
JACK'S GRANDAD
I can make some cardboard templates of each and mail them to you if need be, but the measurements should work fine for anyone used to fabbing stuff.
I made some years ago after I installed the LSx motor in my own P38, but have since removed them. No idea where the spacers are now though......Buried somewhere in the shop!
Martin
Discussion Starter #12
yes, it is a professional shop and they supposedly do well with prototypes and what not so i will go and see what they say. the fronts i am doing level at 42 mm with 4 mm top and bottom plates but on the rears i am going to aim them forward with a 20 mm slope difference as paul suggests.from 52 to 32 mm from front to back inbetween
JACK'S GRANDAD
Good deal.
Just let me know if you need any other dimensions, and I'll see what I can do.
Martin
1 - 14 of 14 Posts
