Hi guys.
A stööpid thing which haves me alienated.
If I go to the car (which is already parked and closed) to get something from the trunk or the glove compartment, I open it and close it normally (without putting the key into contact, to be clear) and I realise nav screen stays on forever. 8-0= I have even went home and returned back to check after 10 minutes and screen was still on.
The only thing I can do to avoid such behaviour (and the battery to be drained) is to put the key in the contact, go to the on position like if I were about to crank it up, and get it off. Then, nav screen is off as normal.
I hadn't find any tip for this in the manual so... any hint? Maybe there is a config tip?
Similar thread with no solution: http://www.rangerovers.net/forum/6-...en-does-not-turn-off-automatically-05-rr.html
