1 - 10 of 10 Posts
2002 P38 4.6 HSE
So. How do I remove the Nav unit form the trunk? Are there special tools. Can you make the tool.
I really want to remove it so I can disconnect and get my radio back.
Also. Below is the model I have. Without the writing on the main part. Which model is it?
[attachment=0:xsjo4voo]NAV.jpg[/attachment:xsjo4voo]
RIP Our Friend
The "SMD4091" tool is the same as the generic radio removal tools available at Schuck's/Kragen/NAPA. You can try skewers or wire brads as well.
2002 P38 4.6 HSE
Very cool. Thanks for the response. I'll have it out tomorrow.
Anyone know which "Mk" my system is?
I thought it was a Mk 3, but another forum showed this as the Mk 4.
If it's got the DVD symbol, it's a MK4. Do you have the same plugs on your old nav? The one P38 unit I saw had different plugs (3, not just 2). The other thing is, as the MK 4 was made for a 16:9 screeen, your pic is going to be 'squashed'.
****, looking over rave and this thread makes me feel like an idiot. I wanted to unplug my unit to see if the white screen/static will disappear, and was taking all the plastics around it off, I could have just pried it out with a pointy metal rod. ughhhhh
Would removing the fuse accomplish the same thing (re-start the system)?
2002 P38 4.6 HSE
Discussion Starter · #6 ·
Thanks to everyone who helped!
I unplugged the Nav and all was well in the sound system.
On that note. Funny thing happened.
When I went to replace the package shelf, I wasn't paying attention to the seat unlatch button.
Replaced the shelf only to discover that the button was missing(slipped out and was tucked nicely under the self).
Had to re-remove the self to move button into place..
Lots of fun. But at least I learned something.
On that note. When I checked the left side, I noticed the button was also missing. So I removed that shelf and popped it into place.
So everything works and I got to clean up/out under the shelves(I would like to know how leaves got in there. I understand the dead moths!).
Once again. Thanks to all of you out there. You have saved my a lot of time and money. And someday I will fly everyone out here for dinner! :dance:
Well removing the fuse on mine for a few days didn't have any effect. Still just a white screen comes on.
Do you think that I need to actually unplug it from the back??
What did you use to remove it or did u just go and get the right tool.
2002 P38 4.6 HSE
Discussion Starter · #8 ·
I think you'll have to unplug the back of the Nav.
I did a search and found the right removal tool.
I then made mine out of a thick gauge coat hanger.
From there it was easy.
You don't have a picture of it handy, do you? Googled Images but came up empty.
2002 P38 4.6 HSE
Discussion Starter · #10 ·
1 - 10 of 10 Posts
