This plug is near the washer bottle - I never unplugged anything so any ideas where it might go or what optional kit it may have run?
Without knowing what year you have there's no way we can check a shop manual or guess.
Hi Toadhall, it's a 94 soft dash RHD, thought wire colours might help but I can't reconcile it.
1995-2002 Range Rover Classic
Paul, keep in mind that in order to cut costs, manufacturers will build a harness common to all models of a single line. to this, items are installed or omitted as market or trim level requires. more than likely it is a connector used on other trim level but not on yours. if all works, I would not worry about it.
If it's any help I have a 1994 soft dash and the same plug is on mine & not connected to anything!
