2016-2018 Range Rover Sport
Hey everyone, in my 2016 sport, when I put the car in reverse, only the passenger mirror dipped.
Now I’m my 2018, both dip. I can’t see to find a setting to change this? I’ve also tried setting the mirror while in reverse and saving the memory.
Anyone else notice this and found a work around for it?
You might have just had a flaw on your 2016. On mine both dippped and I don't beleive I could choose one or the other. It was just both or none. On my 2016 you pick it from the set up options off the steeping wheel list and check enable or disable.
I know that both of mine dip in reverse. The setting can be disabled entirely through the main menu, but cannot be adjusted for one side over the other.
You might be right? I might be getting confused with my 2012 Jaguar XF?
It’s too bad, I really like the mirror dip but when it does both. It’s kinda annoying to pull out of a parking spot into traffic. It forces you to look vs use the mirrors! Lol
