hi...
today finally i have fitted the new Rear Light...
they are beautiful.
i have used 2 resistor for flashing right.very easy to do......
:dance:
i try now after reduced pics (250 kb)
this is the connector on MY10 Led Light
[attachment=4:2yil68c1]IMG_0015-1.jpg[/attachment:2yil68c1]
these are the resistors for fit in parallel from the car
[attachment=3:2yil68c1]IMG_0016-1.jpg[/attachment:2yil68c1]
the Resistor wired with 1mm2 wire...soldered of course.
[attachment=2:2yil68c1]IMG_0018-1.jpg[/attachment:2yil68c1]
you see the red thing is for connect the 3 and 5 pin with the resistor. very easy to find in Italy :)
[attachment=1:2yil68c1]IMG_0019-1.jpg[/attachment:2yil68c1]
one led light fitted.
[attachment=0:2yil68c1]IMG_0020-1.jpg[/attachment:2yil68c1]
you need 2 resistors of 25W and 6.8ohm.
4 plug for fit on original wires.
before close and fix the lights check if you have a problem on your dashboard when the car is performing the testing.
PS:installed the led bulb(white) on reverse gear light :mrgreen:
