1 - 17 of 17 Posts
I'm not kidding. Apparently not all that uncommon either. There's no way a 27mm or tire iron will fit over the stainless steel caps anymore (they used to.) Probably the nut underneath is swollen with rust, due to months of salt on the road.
My next step will be finding 26mm and 28 mm sockets. If the 28mm socket doesn't work I can always pry off the caps and try a 26mm socket or smaller. I'll postpone flat tires until then. `)
Does anybody know what size the nut is underneath the ss cap?
Yep mine have done the same, not all but it is still a pain, who said it's good to have big nuts... `)
Sid.
I should've said 'OMG my nuts have grown!'. :lol:
I have encountered several P38a's with the same problem, some nuts require a 28 socket.
Instead of just throwing them away, I've put 5 on the same wheel and made sure there's always a socket 28 in the car (I use a prybar with socket instead of a wheelwrench anyway).
My nuts have grown too ;)
You didn't get it, it's an anti thief device from Land Rover. The guy using a standard tool will pass his way `)
pry the caps off, clean up your nuts and replace the caps. :doh:
a 1 1/4" works as well if memory serves. i only leave my nuts hand-tight though! :dance:
That's all you can achieve, 'cause 1 1/4" woulde be about 32mm. ;)
I guess a 1 1/8" socket (29mm) would be a better size, but I don't even know if that exists.
i gotta look. i leave the socket in my spare well in case i have to get one off that's mangled. my gut is that you're right and it's a 1 1/8". i was joking about the hand-tight part. i only use it for removal before replacement with a good one.
i only do hand-tight on the steering and braking components b/c those don't matter! :mrgreen:
Discussion Starter #10
LOL `)
Anybody have a good source for replacement lugs or just caps? I'm sure the dealer will want a pretty penny.
I was doing an all 4 wheels brake job yesterday and I have one lug that is just about round, probably from the prior owner or mechanic being a little too enthusiastic with the impact gun.
Rovers North and AB both sell the caps. If the htreads on you nuts are good just give the outter surfaces a wire brush and coating of paint before installing the new caps.
:thumb:
Thank ya Sir!
I have to order a new passenger side manifold, so may as well add a few lugs or caps to the order.
Discussion Starter #14
Not when they bloody welded themselves to the nuts. :x
Still,
you're the man! :thumb:
Thx,
Barge pilot
:? looks better than the last ones I replaced. :thumb:
Jeez! I might just go ahead and take the lazy route and buy a few extra complete lugs with caps. That looks like a PITA! I got enough other work to do on this beast.
Discussion Starter #17
In the end it wasn't too bad. Nut in vise, hammer old screw driver through cap, peel off cap with beefy pliers. The barge spent a night on axle stands while the paint on her nuts dried. ;)
The optional anti-gravity field. :p
1 - 17 of 17 Posts
