Okay guys,
I just picked up the Flip MinoHD and thought I would give it a try here... Many people hate having the useless phone cradle in the center council and I am one of them. So I am attempting to mod it. You can see my progress in the video's below.......
I don't want to waste the space and I did figure out the ground/hot wires... What should I use them for?
Video 1: http://www.youtube.com/watch?v=nTNON32P0vA
Video 2: http://www.youtube.com/watch?v=b5g_DhPPMvY
Video 3: http://www.youtube.com/watch?v=s911XYAlIrc
Video 4: http://www.youtube.com/watch?v=wTXMhYBSIgc
Discussion Starter · #2 ·
Those other wires.
Usually there is:
One that is connected to power only when the ignition is on
One, that when connected to ground cuts out the radio audio. In this case may tell the system that the phone is in use
One that passes data to the audio system
You might find the ignition switched one use full.
For the aux input just splice a shield wire set into the existing line and put a connector where you want it. As long as you only use one at a time it should work fine. Better yet get a stereo audio switch and select which input you want to use.
