1 - 10 of 10 Posts
My 06 HSE has been lifting when I drive, it thinks that I’m in ride hight. The screen is showing that I’m not lifted and my selector switch is lit up on ride height. I like the lifted look but the handeling not so much. Any ideas
Well if the screen and selector shows you in standard height, what makes you think you are in any other setting? If you select wading mode what happens?
It’s in the middle setting now, I have 22” wheels and 265/50 tires usually I only have about 2.5 inches clearance . Right now I have a good 6 inches. It still will drop down and raise up even more
Check the exaust muffler in the eas compressor case aka turtle in the trunk
Exaust muffler in the red circle
M l 1903.
You’re pictures didn’t come through, could you please repost them
I don't have a picture...but the compressor is under the spare in the back. When you remove the tire you will find a hose coming out from the compressor well with a filter stuck in the end. It is usually attached to the side of the the spare well on the forward side.
1 - 10 of 10 Posts
