1 - 18 of 18 Posts
i just bought my 2008 range rover yesterday and i found out last night coming home from dinner that the headlights arent working. my high beams do come on so i was able to get home safely, but i am thinking since both lights arent working it might be a fuse? like i said i am brand new to range rovers and could use some guidance. i have a appointment tomorrow at the local dealership but would like to not use it if possible..
thanks,
bobby
Its odd for both to be out as I believe the lights are fused left/right. And if a fuse is blown it usually indicates there a secondary problem with the ballast.
No other problems with the car that would indicate low battery voltage ie. needs new battery?
Or its possible either both HID bulbs are bad, or your ballasts are bad, or some combo. Either way if you have to replace ballasts and bulbs you are looking at a chunk of change, esp at the dealer.
the battery was dead before i test drove it... so it could be a battery thing.. is there any way i can check it myself?
also there was no owners manuel either.. is there any availabe in pdf format i can download anyone know of?
You can check your battery and alternator with a meter.
Did your headlights work before or did you not check them when you test drove it?
unfortunately i was a little excited and didn't test the headlights yesterday morning during the test drive.
all misspelling aside.. would a low battery cause just the headlights not to turn on?.. everything else is functional..
It usually causes other faults as well (dash warning lights, etc), but HID's are very sensitive to having the right voltage delivered to them. I asked b/c these vehicles are VERY sensistive to low battery voltage. And if your battery is on the fritz, you will encounter all sorts of weird issues that no one can figure out.
I think its unusual that both HID headlights are out together. What does the previous owner say??
It came from a off-lease mega store... and i am having trouble getting a hold of my salesman.. go figure.. on my lunch break i will run it by my buddy at tire kingdom and see if he can test the battery for me..
It seems that if the alternator is working properly, once the truck is started you everything is running off the alternator so the battery would not be involved. As goosey said, you also generally would have additional warning lights.
It is unusual for both blubs, ballast, etc. to be out, but theoritically not impossible. It's also possible you have two different problems (blub on the LH and ballast on the RH, or something). Likewise, if the bulb is out the LCM should report this as a fault.
Do all other light functions work (flashers [with the switch], rear lights, plate lights, etc.)? All the lighting is controlled by the LCM and I suppose it is possible that the LCM is the problem. However, again, the fault-reporting system should recognize this.
Yes, have them load test it. It may not be the issue, but its a good place to start...before you start replacing $$ bulbs and ballasts and other stuff.
And having a good battery will head off other problems down the road.
Discussion Starter #14
all other lights were working.. i didn't try the hazard lights but all turn signals and rear lights worked as well as the high beam. let me check the warning signs again and see if there is something i missed
THe fact that your highbeams are working just fine eliminates alot of possible issues. Being able to drive home with highe beams you surely would have notices dimming or would have triggered error warnings if the battery and/or alternator were failing. Unless some odd obvious switch error has been missed it could be a failing multifunction stalk. I'd let the dealer mess with it, it's only been a day. If they find failed bulbs you'd have to purchase them anyway since bulbs aren't covered under warranty. Chances are the dealership will want to work with you this soon after it left the lot.
Bobby, you just bought this vehicle so taking it back to the dealer would make sense.
I am confused with your statement about high beams working. High beams consist of the xenons with shutters lifted and H7 halogens doing fill-in. I think your H7 hubs are working, and this is what you are getting with high beams on. Your xenons are probably not working, since low beams are handled by xenons only.
Discussion Starter #17
So.. brought it to the dealership.. they said that the left bulb was burnt out and the ignitor was bad.. also the right ignitor was loose.. total repair is about $540 and the wholesale lot agreed to pay $400 of it.. thanks for all the advise yesterday..
1 - 18 of 18 Posts
