1 - 9 of 9 Posts
2010-2012 Range Rover Sport
Hello - After three sets of warped OEM rotors installed by the dealer, I am going to put on a set of aftermarket slotted and dimpled rotors with a lifetime warrantee against warping. Usually, swapping rotors and pads is an easy enough job but I do not want to assume so.
If someone could post the LR procedure for front brake replacement, I would be much appreciated. I'll post a before and after pic when the job is done. Thank you in advance. (Note: the serach function nor the sticky did not yield me the documentation).
· Premium Member
Is the rotor swap procedure on the 2010+ significantly different from the '06-09 one in the sticky?
· LIFETIME CONTRIBUTOR
Removal / installation instructions for MY2010+ (both standard and high performance brakes)
First off, front brake specs (both standard and high-perf.): View attachment 2010RRS-frontbrakespecs.pdf
Standard (HSE) front brakes
Pads: View attachment 2010RRSHSE-Frontbrakepads.pdf
Caliper: View attachment 2010RRSHSE-Frontcalipers.pdf
Disc: View attachment 2010RRSHSE-Frontbrakedisc.pdf
High-Performance (S/C) front brakes
Pads: View attachment 2010RRSSC-Frontbrakepads.pdf
Caliper: View attachment 2010RRSSC-Frontcalipers.pdf
Disc: View attachment 2010RRSSC-Frontbrakedisc.pdf
Front brakes bleeding - Instructions: View attachment 2010RRSHSE-Frontbrakebleeding.pdf
· RIP Our Friend
First off, front brake specs (both standard and high-perf.): View attachment 9627
Pads: View attachment 9628
Caliper: View attachment 9630
Disc: View attachment 9629
Pads: View attachment 9631
Caliper: View attachment 9632
Disc: View attachment 9633
Front brakes bleeding - Instructions: View attachment 9634
VERY KEWL! Even more content for the home pages!
Supercharged and N/A engines share the same rear brakes. No action required on EPB if you are just replacing pads, but if you are doing discs as well see park brake shoe / lining adjustment and bedding-in instructions below.
Rear brake specs (all engines), 2010+: View attachment 2010RRS-rearbrakespecs.pdf
2010+ Rear Brakes
Pads: View attachment 2010RRS-Rearbrakepads.pdf
Caliper: View attachment 2010RRS-Rearcalipers.pdf
Caliper Anchor Plate: View attachment 2010RRS-Rearcaliperanchorplate.pdf
Disc: View attachment 2010RRS-Rearbrakedisc.pdf
Electronic Park Brake
Shoes and Lining Adjustment: View attachment 2010RRS-parkbrakeshoeadjust.pdf
Bedding In Procedure: View attachment 2010RRS-parkbrakebeddingin.pdf
Discussion Starter · #8 ·
Rear brake specs (all engines), 2010+: View attachment 9652
2010+ Rear Brakes
Pads: View attachment 9648
Caliper: View attachment 9649
Caliper Anchor Plate: View attachment 9650
Disc: View attachment 9651
Shoes and Lining Adjustment: View attachment 9653
Bedding In Procedure: View attachment 9654
The rear brakes are much more intensive. Glad I'm just doing the fronts.
2010+ Rear Brakes
Many thanks!!
1 - 9 of 9 Posts
