About a week ago, I had a plethora of error messages come up on dash:
Gear box fault
EBD fault
HDC System not available system fault
Emergency Brake Assist not available
ABS fault
Stability Control not available
IES System not available
Park Brake fault
Plus the driver side headlight has been intermittent, sometimes flickers like a strobe, sometimes works fine, sometimes only on sidelight. Other issues are drivers side heated seat no longer works, plus the TFT dash display gets bright then fades and gets bright again. Car goes into a ‘limp’ mode where it won’t change up a gear but once turned off and on again the car is fine again.
I put it on an overnight CTEK battery charger as I suspected low voltage but it messages reoccurred.
Booked it into the local LR Indy specialist, and today they confirmed it read 48 faults and cleared them, took for a test drive and tried it on and off throughout the day (and confirmed heated seat was both elements needing replacement and a worn out wire).
All was reset but within 5 miles of my drive home every message started flashing up again.
Any ideas?
Hi there did you get an end result to this, I’m experiencing the same issues, drivers side front light flickers, and multiple dashboard errors!
Thanks.
We had this happen while test driving a RRS last week. Dealer took to LR dealer and said it was a faulty ground wire and fixed it.
Faulty ground 100%. Can’t remember if passenger side or driver side, but remove front splash guard, the one closest to the front bumper and you will most likely find a corroded ground wire that will simply break away when pulled! Installed new ground stud, clean up wire and reinstall wire, clear faults!
having similar issues with mine, parking brake flashing brakes locked up cant go forward or backwards, low range is flashing, when i turn the car off i get hdc fault, parking brake non functional, tire pressure monitoring system fault. could it be as simple as a faulty ground wire? would that make the parking brakes lock up?
Your issues sound slightly different in that your brakes have locked up. Check your rear park brake motors to see if they have cracked. Read your faults to get an idea of your codes and go from there.
