G'day,
The light on the top right is the traction control pressure light. I assume it's around a 93 model and thus have abs and traction control on the rear axle. This light turns on to tell us a few things. 1. if the pressure is to low in the accumulator ball for the traction control to work (this is why it's on when you start the car up as the electric motor is charging the accumulator ball). 2. To indicate that the traction control is working, i.e., off road. or 3. To indicate that something is wrong with the traction control system.
Hope this helps.
