well, got it up and running, now when i start it up, oil light goes out as it should, then, after about 10 seconds comes on, any ideas,
i was thinking possible oil pump
any ideas would be much appreciated
Perhaps the pickup tube in the sump has moved, and it pulls the oil level down on start up to a point where it draws air. Can you attach a gauge in lieu of the sending unit?
I dont see a mention of new oil pressure switch, cheap to replace and see.
Oil pressure regulator prephaps..
Low on oil, stupid I know and I would recheck.
Wrong or bad oil filter, to restrictive...
Oil cooler pipe collapsing.
Oil cooler blocked...if engine blew and required complete rebuild I would remove oil cooler and have it cleaned out.
Oil filters have a bypass and metal could easily have gone through to cause more problems
Every engine rebuild no matter what make of vehicle that is ffitted with a engine oil cooler like the P38 should be cleaned out
hi, engine didn't blow, was more of a error on my behalf (cam timing wrong) deffo has low oil pressure, but i will change the switch, and the oil filter again, i did clean out the oil cooler when the engine was out.
well, i'm starting to know these engines pretty well now any way
might just get a new oil pump anyway, whilst i got it off
Hi
Check oil pressure relief valve. It might not close properly causing the lack of oil pressure.
Regards
Jos
Discussion Starter · #7 ·
stripped it out again today, found the oil pump outer gear broke completly half, so i think i have found the problem, any 1 tried the oil pump repair kit, like the one sold by island 4x4, here seems ok, alot cheaper than a new front cover
