Does anyone have a copy of the installation instructions for the bumper guard they could share? I'm interested to take a look to see if it could be modified to fit my 2011. I know the bumper contours are not the same after the facelift, but I'd like to prove it impossible before I give up on the idea.
· RIP Our Friend
Only place I can think of to find older directions is going to be TOPIx. You'll need a one shot subscription to download the directions. AllData could be another source but I am not sure if they have the accessory fitment manual That used to be included in RAVE.
The actual mounting should be very similar with only different bolts needed. Depending on your option packages you may have issues with parking sensors. Naturally follow proper procedures for battery disconnect and observe extra care when working around the SRS sensors and wiring.
very curious if you find something. I tried to fit a wrap-around bush guard to my 2012 and it never worked. The bumpers were too different. The manual says they fit but how to get it working was not obvious.
I'll check topix and see. I thought about the wrap around guard - I believe that was for the 2003-2005 models. It would have looked good as well.
I can't find any option for brush guards or steel bumpers for these models which is interesting. Luckily my park sensors are inop so I don't have to worry about those!
