I'm going to renew all the transmission/axle fluids this weekend, and wondered if anyone has any tips or warnings. On the 'to-do' list:
1. Front and Rear differentials
2. Auto-gearbox
3. Transfer case
I've read that it's best to check you can get the fill holes open before draining the fluid out. Any other words of wisdom would be appreciated.
Thanks,
James
You said it :thumb: , other than being a bit messy, it's a fairly easy job. I bought one of the hand pumps that screw on top of the oil container for ease of filling the diffs.
I'm note sure if you intend to do the transmission filter, but according to this thread it sounds like a right mission: viewtopic.php?f=4&t=36870
I was going to do it myself, but I might take it to the ZF agent down here in NZ.
I did the same. The pump certainly helps.
Colin
I have another question regarding this. The owners manual and the Haynes manual have widely differing values on how much ATF is needed for both the transmission and the transfer case.
Haynes manual:
Transmission 2.6 litres
T-Case 3.1 litres
Owners Manual
Transmission 9.1 litres
T-Case 2.1 litres
Does anyone know which of these is correct. For both the transfer case and transmission can I just fill up to the fill hole, or do I run the risk of overfilling?
Thanks,
James
Discussion Starter · #6 ·
9.1l and 3.1l seems to be the values for transmission and transfer case, respectively.
