Hi guys,
I have just changed my head gasket, everything seems to be fine with coolant(little white smoke, which i heard is normal for a few miles), but i have a slight misfire/hesitation on low rpms, timing wise, i put the cylinder no1 at top dead centre, all 4 camshafts facing up(cuts in them), but i broke a bolt where exhaust attaches before the CAT, and is leaking(loud noise plus smoke), could that be the cause of the hesitation, i didn't drive it at higher speeds because of the noise. or is there something wrong with my timing?
Thank you
What MY is your RR? What engine is in it? Is it SC'd or normally aspirated?
