Backing up from my driveway today I heard this metallic grinding noise it sounded like it was coming from the left front. My steering was turned at full lock and my car was in access height it does this going forwards and backwards it seems to not do it in normal height.
2013-2015 Range Rover Sport
I have the same noise. did you find the fault?
The noise is just the steering stop on the lower control arm rubbing against the stop on the knuckle when there is vertical movement in the suspension. It is normal to an extent and harmless. The fix is to put a dab of grease on the contact point where they meet.
