I know someone here has replaced this in the past (diy), but I could not find it. I intend doing this as well when I drop the pan and do the fluids this\next wkend, its not leaking yet, but looks wet. Rather do it now and be safe. Trying to see if it was as easy as unscrewing it and screwing it back in or do i need to drop the valve body etc to get to it.
Frisco, if you go to the interwebz and type in "ZF Transmission Mechatronic Sleeve" you should get some info ---here's something I found quickly, but I think there is a bit of a trick to pulling out the sleeve that's not shown here (like some sort of wiggle/pull or something...)
http://www.zftranspart.com/images/custom/mecha.pdf
