Preface: I searched and searched and have not found any info on this so I apologize if this is redundant.
What is the max yaw angle before the oil sump can't pick up? I was in a tough spot last month. I was stuck at about a 30 degree yaw with driver side up and I shut down the engine fearing it would not get proper oil to the top end. Is there ever an issue with the oil pick up (aside from the inverted jeep trick in which case the top end will have sufficient oil)?
'06 RRS LUX
SUPER MODERATOR
Haha...good one.
Never had any problems even in extremely steep offroad adventures where crawling along for 15-30 minutes at extremely steep angles was necessary. As long as you are properly filled, I've never heard this concern before...
Thanks. That's what I was hoping to hear.
'06 RRS LUX
