I have an 08 range rover supercharged sport and ive been getting lean error codes for awhile now. While running through the current data while i was plugged in, i noticed the MAP was reading 32 kpa while idling at 650 RPM.
Right now the barometric pressure in the atmosphere in 29 inhg and 32 kpa translated to inhg is 10.
Could the MAP sensor be going bad causing the system to run lean?
