ok, so heres the thing... removed the front grille, headlights and indicator units to carry out rustproofing etc. Refitted the headlights and...i dont even need to switch them on! as soon as i connect the battery the lights come on !! whats happening??!!
Are your parking (side) lights also on?
Has someone turned the headlights on?
Did you disconnect the headlights at the bulb or elsewhere in the wiring loom?
hi p38arover,
the light switch is definitely in the off position. Ignition off. Side/parking lights are off.
Just the haedlights come on.
I disconnected the headlights via the plastic plug behind the headlight ( not the 3 pin on the lamp itself).
the side/indicator units were also disconnected at the plastic plug behind the lamp unit.
verrrrry strange...
